Whirlpool ADP5966 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADP5966 Dishwasher
Viewing 15 posts - 1 through 15 (of 15 total)
  • #34806
    Brains
    Good Afternoon.
    Have the above dishwasher with the report of the indicator behind the on-off switch flasing on and off. Also, machine seems to start then stop.
    Any ideas?
    Thanks for any help.
    Regards
    #244062
    gegsy
    Re: Whirlpool ADP5966 Dishwasher
    Hi Brains
    Do you happen to have the 12 digit NC number as there are numerous ADP5966s 😀
    Brains
    how about 8542 966 15710
    Regards
    #244064
    gegsy
    Yea thats the one Brains 😀
    How many times is it flashing, did they say?
    Brains
    The info I have is that it flashes twice then a short pause & then keeps repeating.
    Regards
    #244066
    gegsy
    In that case you either have a water leak in the base or a faulty/dirty OWI(Optical water indictaor) 3 oclock position in sump when filters removed 😉
    Brains
    Thanks for the help. This is a for a neighbour that asked me to help. I normally only repair cookers etc or do electrical installation. So, please bear with me.
    No sign of a leak (no water on the floor). I’ve just cleaned what appears to be the sensors in the base with a clean duster. There appears to be no water in the sump.
    Looks like they just cleaned/run the machine using a finish cleaner.
    Will the leak be inside the cabinet under the base?
    Whats the best way to access inside to check for leaks?
    Regards
    #244068
    gegsy
    Yes under wash tank. Remove front lower panel (watch the razor sharp edge of drip tray) 😀
    Brains
    Ok. Here goes. Just been to look at it again. Tilted the machine back to pull it out & there is water underneath.
    There is a panel underneath with torx screws in. I assume that I have to remove this to expose the water works?
    (Don’t worry I have pulled the plug etc)
    Thanks again
    not so Brains with Dishwashers 😆
    #244070
    gegsy
    I wouldn’t tell you to pull the plug your Trade 😕 😀
    Remove that, run it again,find leak and fix 😆
    Especially at this little horror:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159
    Brains
    Greg & Chris
    Thanks for the fantastic help. Just running it now to see where the leak is.
    Mrs Neighbour, of course, running around the house in a demented frame of mind 😀 wondering how much a new part will cost. Not yet confirmed its a leak from the big pump. But will let you know in due course.
    So, back to the neighbour & will report back shortly.
    Regards
    #244073
    Brains
    Greg & Chris
    I ran the machine for a full cycle on normal mode. Could not find the leak. Light has stopped flashing. I have no doubt that the problem is still there. I have now reassembled it.
    Mrs Neighbour has now loaded the machine up to use it properly.
    In your view, do you think the big pump may still be faulty?
    Regards
    #244074
    If the outlet hose on the pump lets go, it’ll be a major leak……
    Brains
    Chris
    I’ll take another look at the outlet side of the pump tomorrow.
    I have told them to let it finish & turn off water & power.
    Regards
