Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool ADP5966 Dishwasher Start Light Flashing
- This topic has 21 replies, 11 voices, and was last updated 21 years, 8 months ago by
jnp1980.
May 9, 2006 at 9:55 pm #114293
Tall-Person
ParticipantRe: Whirlpool ADP5966 Dishwasher Start Light Flashing
Many thanks due again guys – our ADP5966 dishwasher developed this fault today and I found the answer here on the forum! We have an extended warranty that runs until October and I thought we might have had to call someone, but the flooded base has been relieved and we are back in business.
I don’t know whether this was caused by a leaking hose or a backflow from the waste, so I will monitor the situation and if it happens again, I will investigate further.
Thanks very much once again. Nice to find a simple solution to a problem for a change!
Cheers,
Raoul. 8)May 9, 2006 at 10:56 pm #114294Penguin45
You’ll need to keep an eye on it – there are various potential leak points on these appliances. Multi function dishwasher tablets don’t help either.
Penguin45,
(Professional Short-Person) 😀 .June 19, 2007 at 12:43 pm #114295rodders123
Does anyone know how to reset the flood switch on a 2900 dish dishdrawer ❓
June 19, 2007 at 7:19 pm #114296Penguin45
ADG2900?
Get rid of the water and it should re-set.
Why have you posted this in this thread – topic is completely unrelated.
Power off before removing any panel.
Penguin45.June 20, 2007 at 7:58 am #114297rodders123
I pre-empted your reply and resolved the issue by reading the earlier comments on this thread. Thanks for your time. An excellent help forum. 😀
June 20, 2009 at 12:18 pm #114298stulidwg
Hi all, I have the same start light flashing problem and have found water in the tray. I’ll tip it out in a min but have not got my user manual. Can anyone let me know where I would find the hose that could be leaking and how to access it as the space under the door is very tight! Thanks.
June 20, 2009 at 4:22 pm #114299Penguin45
Removing the door outer panel, then the lower cover plate should allow plenty of access – power off first, please. There is no one specific hose to aim for, although the outlet hose from the circulation pump is a known weak spot.
There is an undertray which can be removed (2 screws) for a general inspection of the underside of the machine.
Observation is the only answer, I’m afraid.
