Whirlpool ADP6600 light flashing 11 times – now 2 times
Home Forums Public Support Forums International Forums Australasian Appliance Forum Whirlpool ADP6600 light flashing 11 times – now 2 times
  • #54632
    jaxam
    Could someone tell what my dishwasher is doing. It starts to fill then drains and flashes 11 times, pauses and repeats the flashes.
    Cheers,
    Chris
    I have cleaned just about everything and now the dishwasher flashes 2 times. Still need help
    #320391
    jaxam
    Re: Whirlpool ADP6600 light flashing 11 times – now 2 times
    The light flashing 2 times was a one off thing. It is now back to flashing 11 times. 😥
    I started a cycle with the door open and it goes through a drain cycle. Then it begins to fill, but only to cover the filter in the bottom and before starting the wash cycle, it then drains with the light flashing 11 times.
    The one time it failed with the 2 flashes it started to wash but was still filling when the fail occured. I didn’t have the door open for that test so not sure how high the water level got to. No visible leaks under machine.
    Is the flashing 11 times a combination of problems OR is it a cockroach in the control panel.
    #320392
    Optical Water Indicator fault. Your machine is not listed on our tech info, so this is an educted guess. Remove filters and see if there is a clear plastic dome sticking into the sump at the 3 o’clock position. If there is, clean it ’til it’s spotless and try the machine again. No change, replace it.
    If the dome isn’t there, there’ll be a black plstic grid instead. This can fill with fatty deposits, causing the switch behind to give false readings as the diaphragm doesn’t work properly. The spring in the microswitch is prone to failure as well.
    bigsmokepiker
    Can also be a water leakage Fault
    Water can leak onto base & trip safety switch in base
    They usaully can leak from hose thats connected to wash motor
    #320394
    jaxam
    Thanks for the info. I will check for these things. I have seen evidence of water on the bottom tray but I don’t believe it is new.
    The Service Number for my machine is: 8542 660 53969
    I hope that will help tracking down the model.
    It doesn’t have an optical water indicator – it has the black plastic grid with switch. I will check that with a meter to see what is happening.
    Cheers
    #320395
    jaxam
    Just got to the machine and pulled the sides off to find lots of water from the washer motor hose being off. I disconnected both pumps to check if anything was stuck in them the other day and could not have refitted the washer pump hoses correctly.
    I also pulled the water flow switch and that was completely full of fatty deposits. I cleaned it out, checked and refitted, made sure all hoses fitted correctly and turned it on. It now works as it should.
    Thanks Penguin 45 for your knowledge and bigsmokepiker was spot on the money with the washer motor pipe causing a leak.
    The model number for the dishwasher is ADP 6600 IX and the Service Number is: 8542 660 53969. It is made in Germany and sold in Australia.
    Thanks again
    #320396
    pieter123
    I have the same problem with the 11 times. Can one remove to black plastic grid from the inside of the machine or do one have to enter from the outside panels?
    #320397
    Twist fit from underneath.
