Whirlpool ADP6946 F5 error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADP6946 F5 error
  • #21042
    shaggyd
    Hello again, we have got a new dishwasher ADP6946 as a replacement for a faulty dishwasher. Our new one now has a delay in power when the dishwasher is switched on and after a minute, it flashes F5.
    Any ideas?
    #189267
    DentedPorsche
    Re: Whirlpool ADP6946 F5 error
    Unless they’ve changed their fault codes it’s reporting a blocked spray arm.
    As it’s a new machine I can only suggest calling and getting an engineer out to it.
    DP
    #189268
    stormrider
    Hello !
    I’m french and also look after a solution for this poblem.
    I received my dish washer completely new and it got the same problem.
    unfortunally, the brand is uncapable to provid etechnical informations to repair man, provide wrong information about the error code ( I’m sure that’ you’ve checked that your spray arm is running well…).
    My dishwashe felt in work after been tested by the reparator. The only things I changed is the position of water stop located in the water incoming. It was previously horizontal ( because on the floor, with an extention ). Now it is vrtical.
    Don’t ask me how it can change anything, I’m reduced to watch the difference : now it works ( pretty well !! ).Another question : how long will it work ?
    #189269
    shaggyd
    The fault cleared after I found a bit of food on the seal of the door. I`m guessing that F5 is door/latch related.
    #189270
    stormrider
    shaggyd wrote:The fault cleared after I found a bit of food on the seal of the door. I`m guessing that F5 is door/latch related.
    well you’re lucky !
    Could you explain where exactly did you find some food ? At the bottom ?
    Thanks for the informations !
