Explanation of this error code is not in the manual. Searched this forum and cannot find other posts referring to this. Any ideas what it means?
f6 is usually the water metering impellor. either bad connection or seized wheel or faulty reed switch. or water turned off or blocked in-line filter or broken wire in door loom.
