whirlpool adp7966 flashing start button
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adp7966 flashing start button
  • #41134
    pete22070
    hi
    my previously faultless dishwasher has suddenly developed a flashing start button which doesnt stop and you cannot override it any help would be most helpful
    thsnks pete
    #268901
    Re: whirlpool adp7966 flashing start button
    Count the pattern of the flashing light, ie 1-2-3-4-pause-repeat. It’s an error code.
    pete22070
    thanks for speedy response penguin – its flashing x2 . any ideas appreciated
    #268903
    Flood protection activated – there is water in the base tray under the machine. Drain and find the leak – power off first.
    pete22070
    okay thanks , what is the probable cause of the leak , is there one thing more common than anything , and is it an easy fix
    tia
    pete
    #268905
    gegsy
    Usual culprit is a split in the small hose off the re-circulation motor.
    Run it and look for the fountain 😉
    pete22070
    thanks for reply will look tomorrow , is that pump in the machine , ie under base tray , or is it external
    pete
    #268907
    THIS particular sin before God……..
    Shockingly bad.
