whirlpool adp8322 d/w
  • #14883
    jeremy
    the fault is that it will do the quick wash (40c) programme ok, the other two (50c,65c) it fails after apporx 1 hr with f4 which is apparently ‘F4. Draining failure. Drain pump, control board OWI or water indicator defect.’
    There isnt any water left in it at the point of failure, plenty of heat in there too. so any ideas ? and what does OWI represent?
    regards
    Jeremy
    #161169
    Dave_Conway
    Re: whirlpool adp8322 d/w
    OWI refers to the WI (water indicator) no idea what the O means 😕
    The water indicator is the diaghram switch in the sump by the looks of it.
    #161170
    DentedPorsche
    Some machines are fitted with an Optical Water Indicator (Turbitity sensor). (Seem to remember this from Whirlpool Training days).
    If memory serves me right it’s in the sump somewhere
    As the fault is temperature related the NTC could be causing the problem. (The error codes aren’t always correct).
    Brian
    #161171
    Simon46
    Ive got one on Friday F4 but is draining o.k. Will report back.
    S.
    #161172
    The optical sensor lens gets dirty, sometimes just a clean is all it needs.
    Right hand side of the sump about 75mm in diameter, its black if I remember correctly.
    Kevin
    #161173
    clivejameson
    Dave_Conway wrote:OWI refers to the WI (water indicator) no idea what the O means 😕
    ‘Orrible ???? 😆
    #161174
    jeremy
    thanks for your input i will investigate said owi !!
    regards
    Jeremy
    #161175
    DentedPorsche
    In the distant past, when I worked for the now defunct Whirlpool agent, I had a few machines giving f4, of the ones I remember, two were syphoning, one had a flooded base and another was cured by rewriting the software to the module.
    Brian
    #161176
    Simon46
    Was Spaghetti fom Spag Bol in the OWI. F4 reported intermittent then constant.
    S.
