A customer’s Whirlpool ADP8322 dishwasher is stopping the programme after about 3-4 minutes and showing an F7 fault (7 flashes). It runs through the test programme in 10 minutes but does not display any fault codes.
Having read other postings I am suspecting the flow meter but there doesn’t seem to be any water running past the sensor when the machine is filling.
The intake valve is working as the machine fills in a reasonable time, the solenoid on the water softener tests out OK and I have already replaced the WI.
I am beginning to suspect the module.
Any suggestions would be very welcome.
If you had a sam meter you can reprogramme control board and 9 times out of 10 the f7 will clear. If you change the flow meter it will definately clear the fault. I’ve never changed a valve for f7 but it could happen
