Whirlpool adp8500 odd fault
  • #48089
    bubs
    Hi, strange dishwasher fault week….
    Have a Diplomat (whirlpool) ADP8500 (8545001157400) to repair.
    When you start the cycle during the drain and fill part the whole machine pulses on/off, the fill valve, drain pump and display lights pulse on/off together.
    If you wait for it to fill the circ pump kicks in and it sounds fine and the display light stays on. I measured a steady 240v at the display pcb so maybe this is faulty but would this affect the drain pump and fill valve?
    Found a similar fault in your archive but not any answer.
    The main pcb in the base looks fine, no bad connections.
    Anyone had similar?
    Graeme
    #295543
    Re: Whirlpool adp8500 odd fault
    had similar faults like this before normaly the power supply on the pcb timer
    a lot of appliances use a capacitor to drop the voltage down from 230v to 20 or so to supply electronics. As these caps get older their resistance rises causing voltage to drop. it is a similar effect to low batteries
    in you scenario you turn on voltage drops electronics stall swich off and as the voltage rises switch back on again
    hope this helps
    martinm
    Also have seen the insulation reading being low cause this on these dishwashers as well
    #295545
    bubs
    Thanks Guys, yes its similar to the whirlpool fridge pcb faults.
    #295546
    keithwilliams
    we’ve got a couple of other threads running about this. i’m pleased to see capacitor mentioned here cos i just summised in my thread that this may be the case. please please if any of us solves this for sure can we please let everyone know how.
    thanks
    keith
