I removed the water inlet solenoid and a mains bench test appeared to finish it off. An old inlet valve works on the bench but not in machine. The diswasher when turned on will empty water out and then stop with a flashing light (no pattern). From the moment of being switched on about 80volt is being sent to the inlet solenoid. Is this a PCB fault or ???
Constant flashing is indicative of a problem with the temperature control circuitry. Put ‘whirlpool AND ntc’ into Search for this forum only for pages of info.
