Whirlpool AFB6640 Freezer Alarm
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool AFB6640 Freezer Alarm
  • #35421
    Jonathan T
    I have a whirlpool AFB6640 freezer. The pump runs fine when the machine is first switched on and is given a jolt but then later will not restart unless I again hit/jolt the freezer. As a result it gets down to temperature and then defrosts/warms up as pump does not cut in later on . I am assuming it is a problem with the thermostat which is part of the circuit board as can’t see a seperate thermostat.
    Does this sound like the right problem as i don’t want to buy anew circuit board for no reason, and also where can i get a circuit board (ITW ISPRA Controls TP723100 I think) from.
    thanks
    #246467
    amg24
    Re: Whirlpool AFB6640 Freezer Alarm
    Replace the faulty relay with the better quality: OMRON G5LE-1-VD 24VDC
    many whirlpool freezer uses bad relay (SCHRACK T7NS5H1-24-WG-A)
    price less than GBP £10
    Done.
    #246468
    sylvester
    Thread a few months old, where did you get the omron relay?
