Re: Whirlpool AFG 7080 warming up
I have decided to take the control panel to bits as I can’t see what else could be causing this problem. I’m not an electrician so I am not sure what the component is (transformer?) but the large rectangular component was very hot and has discoloured the pcb and the plastic below it, could that be the cause of my problem? If so what is the correct terminology for it so that I can try and order a new component. To tight to cough up for a complete panel which is the only other alternative I think.
Markings I can make out are MACOM (I think) Pri 230V 50/60hz sec 9V 15Va
also 1012M109
and 17011020
any help would really be appreciated.
