Re: Whirlpool AKG218 Main Oven not working
Sounds like the selector switch,the contacts often fail/burn out,it’s quite obvious when you see this as it’s black and burnt,unfortuneately they are on underneath of the selector switch so not easily visible.
You need to remove control panel facia to access the two securing screws which hold the switch, the control can then be turned over to view.
Could be a failed connector on the neutral side,maybe at mains connector at back. It’s a case of taking off the facia to get to the two screws which release the selector switch,you can turn it over and view the underneath of the selector.
Be VERY VERY careful, switch off at main switch and consumer board,you are dealing with 30amp/ 7 k’s and there are no second chances,would suggest you call an engineer if in doubt.
