E5 is either a low voltage problem or faulty eeprom in the filter pcb, check voltage, if ok the filter board is faulty and that is over £700 with vat, also most of these units now need the induction boards changing as well as they have changed many of the plugs and harnesses, either way if not down to low voltage then it’s a write off
