Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirlpool AKP950 double oven
- This topic has 9 replies, 2 voices, and was last updated 14 years, 2 months ago by
Miketheleak.
January 14, 2012 at 3:27 pm #67368
Miketheleak
ParticipantCan anyone let me have the circuit diagram and maybe even the manual for this oven please.
I thought I’d fixed it, the bottom oven was dead but top oven ok. Now everything is working but the cooling fan for the bottom oven is not turning off.
There does not seem to be anything wrong with the toc’s as far as I can tell. 😕January 15, 2012 at 1:24 pm #367233spimps
ParticipantRe: whirlpool AKP950 double oven
Have you got the 12 digit number,might have similar but cant find the mod you gave although my sios cd is a few years old.
January 15, 2012 at 1:53 pm #367234Miketheleak
There is a plate on the oven but it is totally unreadable, I got the model number off the instruction book that the customer had kept. This one has got 2 oven cavities each with their own cooling fans, it has 4 toc’s, 2 at the back of each cavity. It looks like the AKP802 from the front. Any info would be very helpful.
January 15, 2012 at 2:58 pm #367235spimps
Pm me with an email I should have one,no service manuals just wiring diagrams.
January 15, 2012 at 8:13 pm #367236spimps
Sent as pdf,looks to have gone OK.
January 15, 2012 at 9:00 pm #367237Miketheleak
Sorry it arrived as winmail.dat nothing I’ve got will open it.
But thanks for trying I appreciate it.January 15, 2012 at 9:02 pm #367238Miketheleak
Can anyone please let me have a manual or circuit diagram for this type of oven.
January 15, 2012 at 10:20 pm #367239spimps
Problem is sios disc is copyright protected,have to print it off then scan it,save it and email file.
As I said they dont do manuals just diagrams and fault codes in sios.
Struggling to see why the pdf hasn’t got through,I sent a copy of that to my other emails just to check and its fine 😕January 21, 2012 at 9:01 am #367240spimps
Confirmed that item was rec’d in pdf by Miketheleak.
January 21, 2012 at 1:35 pm #367241Miketheleak
Just to clarify, I received a winmail.dat attachment that contained the PDF. I’d never come across winmail.dat before ( I’ve obviously led a sheltered life) so it took me a little while to work out how to open it. Once I’d done that it helped enormously, the reason for the fault was much easier to locate.
I would just like to say thanks again to spimps for his time and all the help he gave me. -
