Re: Whirlpool AKZ146/1X oven control issues.
hi,
you may not need a new board.
take the board out and examine the sloder joints closely under a magnifying glass.
the heat often causes “dry joints” and may have to re solder where they have gone dry.
a hint where to look, if it resondst to moving the wire coneector to the board, its most likely the block connector tracks, try running over them with some solder.
hoep that helps
post back with your result
