Whirlpool AKZ151/1X wont move off stop
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AKZ151/1X wont move off stop
  • #35530
    monkey
    Hi Guys
    I have replaced the switch but you set the time.It wont change from the stop display.Any idea which board could be faulty.
    #246961
    johnmac11
    Re: Whirlpool AKZ151/1X wont move off stop
    I take it you changed the pushbutton switch??
    To set the clock you first have to make sure the oven selector knob is in the off position, and IIRC press the start button 3 times till the display lights up in the bottom r/h corner, then use the r/h temp selector knob to set the time. Once time is set press the start button once again and the oven should work.
    John
    #246962
    monkey
    thanks
    when you press the button nothing is happening.I have tried pressing it 3 times.
    #246963
    DentedPorsche
    monkey wrote:Hi Guys
    Give us the full story then. Why did you replace the switch? What was the original fault.
    Switch it off at source. Put the controls (oven selector) to off. Power it on again. Press the switch button 3 times, you should be able to set the time, if it came off stop.
    Brian
    #246964
    monkey
    I changed switch because it was sticking.But after I changed it I found it had not fixed the problem.
