Unable to clear “stop” to operate oven, selector button switch in the middle is ok , anybody know which P C B might be at fault ? Thanks.
no fault code .
Make sure that the oven function switch is in the off position as you cannot set the clock otherwise. If it is at off and you still cannot set the clock it is usually the the button switch in the middle causing the problem.
