Whirlpool AKZ151/wh not heating
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Whirlpool AKZ151/wh not heating
  • #46557
    bluemoonste
    The power tripped out last night and now the oven will not heat up. Everything else seems to function fine though.
    Could it be the thermal fuse or element and how do I get to these and test them ? More importantly where could I source replacements from ?
    Appreciate any help you can give me …. grilled pizza is no fun !!
    #289959
    Re: Whirlpool AKZ151/wh not heating
    Almost certainly the fan oven element gone from your description – you’ll need one of THESE.
    Power off if you intend to deal with this yourself.
    bluemoonste
    Many thanks Penguin45. Is it just a case of taking the back off the oven and pulling it out ? Are they easy to fit ?
    #289961
    You need to remove the inner panel from the rear of the oven cavity for access – it is basically a screwdriver job.
    bluemoonste
    Thanks again, I’ll give it a go.
    #289963
    bluemoonste
    Managed to get the heating element out tonight and measured it with an ohm meter. It measured infinity, does this mean it’s goosed ?
