Whirlpool AKZ161/03/IX 858516115122
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AKZ161/03/IX 858516115122
  • #81289
    Alanj
    Hi guys, above built in oven is coming up with F03 on main fan oven.
    Does anyone have a service manual they could email me?
    If the oven is switched off at mains then switched on again it still shows F03, but if you then hold the start button for 5-10 secs there is a beep and what looks like a S or 5 in the left hand of the display and 00-05 can be selected on the right of the display. Is this a test mode?
    Alan
    #416093
    Alanj
    Re: Whirlpool AKZ161/03/IX 858516115122
    Anyone got configuration codes for this appliance power board? There are no resistors to cut on this board. Replacement board I ordered from Connect is part number 480131000151, is this the correct board? I have tried using the sheet included with the board to configure it but function switch instead of corresponding to the three functions and off settings, it has extra settings in between. Any help would be much appreciated.
    Alan
    #416094
    Grendal
    Try 05 that is what is listed for that oven
    #416095
    Alanj
    Hi Grendal, thanks for the reply. Do you know if board I’ve ordered is right for this oven? Have found 3 different part numbers listed.
    Alan
    #416096
    Grendal
    Hi just looked up the pt no and I get 481231019121 Control board 9M Models
    not sure if the code changes and I cant check it sorry
