Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirlpool akz451 power unit configuration
- This topic has 6 replies, 3 voices, and was last updated 14 years, 9 months ago by
Dan76.
June 26, 2011 at 8:38 pm #63599
Dan76
ParticipantHi All,
Does anyone know how to configure the power unit on one of these ovens. Replaced blown unit but oven only displays F03 which is unconfigured board.
Your help is much appreciatedJune 26, 2011 at 9:19 pm #354263johnmac11
ParticipantRe: whirlpool akz451 power unit configuration
On some of these you just cut some resistors but on the newer ones you need a SAM module. What was the part number of the board that you fitted?
JohnJune 27, 2011 at 11:54 am #354264Dan76
Hi John
Its not the zodiac style pcb that have the group of resistors to cut out. The part number is 481221458447. It does have a plug in it which I dreaded might be a coding port
Cheers
DanJune 27, 2011 at 1:10 pm #354265johnmac11
Looks like this is one that uses the SAM module to programme it. It has been a few years since I did one of these but IIRC I think it can be programmed from the front buttons on the oven.
Hopefully one of the current Whirlpool engineers can confirm…
JohnJune 29, 2011 at 12:19 pm #354266Dan76
Cheers John I’ll wait with hope and anticipation!
June 29, 2011 at 6:30 pm #354267DentedPorsche
Few years since I worked for them I’m afraid, but, the information I have is as follows:
When setting the configuration code manually note that step 2 has to be completed within 60 seconds.
1. Rotate Function Selector to the “OFF” position then
disconnect oven power supply.
2. Reconnect the power, push and hold the Option Selection
Button for 5sec, the Acoustic Alarm Beeps.
3. Push the Option Selection Button 4 times consecutively
within 8 seconds. The Configuration Code is shown in the
display.
4. Push and hold the Option Selection Button for 5 seconds.
The value in the display will now start to flash.
Rotating the +/- Knob changes its value.
5. Push and hold the Option Selection Button again for 5
seconds to store it, the display stops flashing.
6. Leave the machine for 2 minutes or disconnect then
reconnect the oven power supply or rotate the Function
Selector clockwise to “OFF” position to exit the setup.Brian
June 30, 2011 at 12:53 pm #354268Dan76
cheers Brian, I’ll have a crack at this tomorrow
Many thanks
Dan -
