Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AKZ516/NB PCB configuration
- This topic has 5 replies, 2 voices, and was last updated 1 year, 7 months ago by
bmrenr.
August 30, 2024 at 12:52 pm #102939
bmrenr
ParticipantHi I have the above whirlpool oven with service no. 85855165010 and the main PCB had blown so ordered new one part no. 480131000151. This board is programmed but it says I still have to configure it by pressing buttons and turning dials, but I can’t seem to do this. When I turn on oven first I get F03 which I think is unconfigured board, I then tried following instructions that were given but I can’t seem to configure it. When I started I was getting beeps when I was pressing buttons but now I’m getting nothing just F03. Does anyone know if I can reset and start from scratch or have a step by step how to configure this.
Tom.September 3, 2024 at 7:01 am #491152baron
ParticipantYes, do you need to configure/set the board.
The procedure has to start in the 10s from plugin into powerline.
Do not forget to set bit “ON” after setting the XX/YY number that you have on oven label… Otherwise you get back into F03 stage and you have start again thru disconnecting from power…September 3, 2024 at 11:05 am #491153bmrenr
ParticipantHi Baron thanks for the reply when you say disconnect from power how long does it have to be disconnected before I can start again. The xx/yy has me confused as well as there is no x or y on the oven label I will attach photo of label.
TomSeptember 4, 2024 at 10:34 am #491154baron
ParticipantUnplug just for few seconds… at least 20…
On the old tech manual is written 36 for “Konfigurierungscode”… I think that will fit.September 4, 2024 at 11:49 am #491155bmrenr
ParticipantThanks Baron I will have another go at it tomorrow if customer is at home.
Tom
September 6, 2024 at 3:43 pm #491156bmrenr
ParticipantThanks for your help Baron I eventually got it configured, I must have had a loose connection from option button because when I started today I wasn’t getting any beeps when pressing the button so I took off pcb behind display to have a look at it and when I put it back together it was beeping and I could go through the steps on leaflet. I would have been stumped with the X and Y when I got to that step only for your info so thanks again.
Tom.
