Hi all
This oven has just tripped it’s overheat cut out for the second time with just over a months gap between the two events, each time I have reset it and tested the oven to find that it has perfect temperature control and that the cooling fan runs nicely, the customer can also confirm that they have not turned off the wall power prematurely (they don’t turn it off at all) and that in both cases it failed after it was finished with for the evening (they only discovered it when they came to use it the next day).
Are there any known issues on these? Also is there a service manual available which would tell me of any parameter settings on the board that I may be able to change?
12nc: 852577238001
Ser: 141139027025
Thank you
Jem
