Whirlpool Amercian fridge temp problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool Amercian fridge temp problem
Viewing 1 post (of 1 total)
  • #45881
    DavidMcC
    Hi I was wondering could anyone help I’ve had the usual problem with the circuit boards and I’ve replaced both front and rear boards now everything works fine but the new problem is the fridge won’t reaeh is set temp and the display just flashes C all the time when I check the temp with temp gun its not what it should be its around 9oC. I was wondering what senses the fridge temp and controls it and can I get a replacement part. The freezer side is perfect holds temp fine.
    Any help would be great Thanks David
