Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool American dryer 3rleq8033sw1 heating problems
- This topic has 4 replies, 3 voices, and was last updated 10 years, 10 months ago by
mbdas.
May 16, 2015 at 11:35 am #84981
mbdas
ParticipantHi I’m having problems with this dryer and it’s doing my head in , the red spot stat on the heating element housing keeps going o/c after 2 loads. I’ve replaced all the stats on element & exhaust duct and made sure there are no blockages but still no joy 😥
I’m I missing something here , can someone help please!!!!
Thanks MarkMay 16, 2015 at 12:32 pm #427361electrofix
ModeratorRe: Whirlpool American dryer 3rleq8033sw1 heating problems
its got 2 be one of 2 thing
1 airflow
2 the wrong stat1 this dryer is a vaccum type. ie the fan pushes the air out that lowers the pressure in the drum. the only way air can get in is over the elements. if the drum seals are faulty the air will not come in over the elements causing it to overheat
2 the wrong stats
go here
http://www.maytagpartsonline.com/
put your model in and get maytag part number. should be the same as printed on your stat
plus did you change both stats on heater ?Dave
May 16, 2015 at 7:41 pm #427362mbdas
ParticipantRe: Whirlpool American dryer 3rleq8033sw1 heating problems
Thanks for the info & web site just discovered one of the stats was the wrong part listed on connects web site, hopefully if I fit the right one this should sort it . Thanks Mark
May 16, 2015 at 9:27 pm #427363electrofix
yes i had that problem with connect am waiting for rep to pick it up and credit me
also make sure outlet hose is metal type not plastic. but dont order from connect they got that wrong too. so got one from wickes
May 17, 2015 at 9:02 am #427364EFS
I had one of these dryers doing this on a regular basis.
It was in a care home working round the clock drying towels.
I suspected overloading but of course they would never do that.
Anyway I solved the problem by rewiring the temp selector so that it was not possible to select high heat and all is well two years on.Btw. The one shot stat on the heater box can be reset by freezing it then give it a sharp tap 😉
Steve
