Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirlpool american f/f s20b rss31-a/g display flashing
- This topic has 5 replies, 3 voices, and was last updated 15 years, 11 months ago by
mikethemechanic.
April 16, 2010 at 4:12 pm #54018
mikethemechanic
Participanthello guys,
try and avoid repairs on side by sides but good customer of mine has a problem with this one
mod: s20b rss31-a/g
service number 8586 151 15010
serial:11 0241 008501
the ice maker is not working and the whole temperature display is flashing on and off constantly it will dispence water but not ice they went together so i supect they are conected.
i have examined both the board behind the dispencer and the rear power module and cannot see any obvious problems
i suspect the module behind the display is the problem but have not had this problem before all conections are tight and you can atually hear the relay turning the display on and off
has anyone had this problem if so what were your findings and where is the best place to order this module qualtex, connect?? this site
i would appreciate your help
many thanks
mike (north west appliance solutions)April 16, 2010 at 5:59 pm #318081chezza
ParticipantRe: whirlpool american f/f s20b rss31-a/g display flashing
i would check the evap motor is working correcty, and evaporator isnt blocked with ice ( ie not defrosting properly ) before changing boards…
by the date code of the serial number, you would need to replace front and back board if this does turn out to be the issue , due to compatability issues , but def worth checking the other firstedit .. also worth checking the condensor isnt choked and the condensor fan is working
April 16, 2010 at 9:11 pm #318082mikethemechanic
sorry youve lost me ??
the fridge and freezer are working perfectly and water dispencer works just the display flashing and ice maker not working?
did you understand that?
cheers i just didnt understand how the evaporator being choked would make the display flash and stop the ice maker working, if you try to dispence ice the bulb for the dispencer also flashes
cheers mikeApril 16, 2010 at 9:21 pm #318083eastlmark
ModeratorRe: whirlpool american f/f s20b rss31-a/g display flashing
Might be worth a shot with THIS first.
April 16, 2010 at 10:31 pm #318084mikethemechanic
you star that sounds like it will do the job!!!!
mikeApril 17, 2010 at 6:49 am #318085chezza
mikethemechanic wrote:sorry youve lost me ??
cheers mikeYou asked for advice, which i offered from my experience to check before paying a lot out for parts not neccesarily needed .
i wont bother next time -
