Re: Whirlpool american f/f s20drbb32-a/g
if you take the two screws out on the ice dispenser panel behind that another plastic panel with another two screws. This will allow you access to the bracket the hose clips to. you can then feed a new tube in from bottom of door. You can buy the hose from any hydraulic or phneaumatics place. To get to the bottom coupling you need to take plastic trim off the bottom of the fridge freezer which is two philips.
Have fun
