Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool American F’F display problem
- This topic has 9 replies, 7 voices, and was last updated 17 years, 5 months ago by
Seamy.
November 7, 2008 at 3:05 pm #40839
Seamy
ParticipantService num’ 858615115011
digital display flickering & going off, appliance still runs.
Any ideas what i should be looking for?
Loose connections or is it a duff display?November 7, 2008 at 3:12 pm #267732funkyboogy
ParticipantRe: Whirlpool American F’F display problem
new display pcb, had it a few times,
allyNovember 7, 2008 at 5:17 pm #267733Seamy
any idea of part num, please
ta
November 7, 2008 at 5:27 pm #267734robbo1973
i also have one with a dodgy display is this the kind i have read about where you have to change both pcbs or is that when the main one is faulty?
November 7, 2008 at 6:29 pm #267735funkyboogy
dont know the part no im afraid,
but i can say i have fitted 10 + whilst doing some whirlpool work and only ever fitted front pcb..no probs..ally
November 7, 2008 at 7:46 pm #267736smartin
id be checking connector block under hinge cover on top of door 1st before ordering anything.
November 7, 2008 at 8:28 pm #267737funkyboogy
possible, defo worth checking,,but unlikely if its a loose connection display would normaly be blank ?…
this flickering is a known fault with these w/pool models..
allyNovember 7, 2008 at 8:35 pm #267738geoff1
The versions I have had (858616615010) not only does the display flicker but you can here relays clicking. Whirlpool have modified the main board ( fitted rear bottem) for this fault and depending on model you may have to change both boards.
The is a topic already started somewhere which has some of the differences on
Geoff
November 8, 2008 at 9:11 am #267739DentedPorsche
Hiyas,
If the serial number begins 110330 or lower then both boards have to be replaced.
After this date code the machine is fitted with the later electronics and individual boards can be replaced.
Any early appliance that has previously had the boards replaced are, of course, treated the same as the newer appliances.
HTH
BrianNovember 11, 2008 at 8:02 pm #267740lerch
FF is normally a sensor fault. 😀
