Whirlpool American F’Freezer Fault code?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool American F’Freezer Fault code?
  • #20856
    Seamy
    Anyone know what F99 or F1 fault codes are on these, i suspect something to do with water system as customer says they recently replaced filter, do they have to reset appliance after doing this or will fault go away after filter replacement? I would imagine theres some sort of swtch in there that filter engages against? Any ideas..
    #188574
    ali-p
    Re: Whirlpool American F’Freezer Fault code?
    Yep, its the filter indicator – F99 is a new filter, F1 is a filter that needs replacing – its all done on a time basis (6 months)- if the water dispenser is not used it still counts down
    From memory, press & hold ‘OK’ to reset after replacing the filter
    If you need any filters, let me know by pm
    #188575
    Seamy
    Cheers Ali
