Whirlpool American Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool American Fridge
  • #44764
    mussels
    Hi all,
    Can anyone help me please with a problem i have with an American side by side fridge.
    My 5 year old (S20B RWW20-A/G), Model no (8586 152 15010), fridge/freezer has stopped working,
    Everything defrosted and i can hear that the compressor is not functioning, although the fans, module lights, bells & whistles, seem to be ok etc.
    I’ve put this down to a switch on the printed circuit board at the bottom/back right hand side in a white plastic case, the reason is a couple of times i gently tapped the micro switches and the compressor cut in now and again, there are 3 black switches and one red, and i think i’ts the red cased one that has the fault.
    Any idea of the price of a new board, or is there a cheaper alternative?
    All help much appreciated.
    Jeff.
    PS, The board has a label with these numbers on (SPEA OK CU800000 BH)
    #282234
    mussels
    Re: Whirlpool American Fridge
    Just tried changing the end capacitors around like suggested on a similar thread, but it’s a no go!! 😥
    Cheers.
    Jeff.
    #282235
    mussels
    Tried plugging it in again and the freezer display reported C/F, can anyone tell me what this indicates please?
    Thanks in advance.
    Jeff.
    #282236
    Hi Jeff,
    The error is telling you that there is a communication error between the main and interface board, the recommendation is to replace the main board.
    The board is listed here
    HTH
    mussels
    kwatt wrote:Hi Jeff,
    HTH
    K. OK and Thanks for letting me know, I wasn’t sure if it meant (compressor failure) or something.
    Cheers K.
    Jeff.
