We have a Whirlpool 6th Sense American Fridge Freezer, model SB54QW. The fridge has suddenly stopped cooling whilst everything else is working fine.
Having looked through previous posts I have taken the front grill off and cleaned it thoroughly and similarly the lower metal back plate and done likewise. The compressor pod is pretty hot but the cooling fan is working.
I have also followed the fault code guide and that shows fine except at end it showed a flashing 0/1 fault code (water dispenser fault) but there is no issue with the ice or water.
You mention in previous posts that the airflow/motorised baffle may be a problem in these situations but where is this situated and how do I do a quick check to see if it is working properly?
Any further help would be appreciated
Alan 🙁
