Whirlpool American side by side, 2 dashes in display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool American side by side, 2 dashes in display
  • #21952
    Seamy
    Got a customer who tells me her Whirlpool American style side by side fridge freezer has stopped functioning. It seems to be running but two dashes appear in display and alarm is sounding. She says display still reads -18 and 5c as normal. It is not freezing and food seems to be defrosting. Does real temp’ not display? I suspect this is setpoints. I’m experienced at these brutes and only do thermostat changes on refrigeration.
    #193145
    Re: Whirlpool American side by side, 2 dashes in display
    If 2 dashes appear, then there cant be 18 on the display!?!
    If it is defrosting, check there is power to the compressor, the Temp sensors rarely go wrong. It will more likely be the control board.
    Does it need a regas?
    The 18 and 5 are what it is set to, wont flash temperature unless it is below -12 if I remember rightly.
    Take the lback cover off in the freezer and check the back is fully frozen
    #193146
    Seamy
    She said its showing — two dashes and alarm sounding. When she resets alarm it will go for a while & show -18 and 5c. But will alarm again after a few hours.
    I advised her to contact Whirlpool for repairs as i don’t do Refrig’ work, just fit the odd t’stat.
    #193147
    Seamy wrote:She said its showing — two dashes and alarm sounding. When she resets alarm it will go for a while & show -18 and 5c. But will alarm again after a few hours.
    good call! 🙂
