Whirlpool American Style Dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool American Style Dryer
  • #96299
    suedehead1
    originally the motor was making a horrible screeching noise but not turning, then it would cut out,
    after 5 minutes I could press the start button and it would do the same.
    I tried turning the drum with door at the same time but it would not turn.
    I fitted a new motro first time ever, It worked ok but after 2 loads it will only
    turn if I give it a push exactly as if it needed a new capacitor.
    I had the machine in bits and there is no capacitor.
    I assume the new motor is faulty and advice welcomed.
    #462935
    suedehead1
    [h=1]3rleq8033rw[/h]
    #462936
    nothing else it can be apart from the motor
    you can check if the correct one has been supplied
    https://shop.ukwhitegoods.co.uk/481236138027-whirlpool-american-style-tumble-dryer-motor
    suedehead1
    i will check thanks
