Whirlpool American style fridge freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Whirlpool American style fridge freezer
  • #55090
    tatters
    We have had the above product since Nov 2006 , in the past 4 months the fan on the freezer side comes on and stays on until eventually the alarm sounds and the temperature shows a hyphen. A local engineer advised me to take the panelling out of the freezer side and defrost the element with a hairdryer , this i did and everything went back to normal. Over the last couple of months this has happened more and more regularly . Reading the manual and listening to other advice items in the freezer have to be placed so as not to disrupt air flow , this we did the last time it went off and lo and behold the alarm went off. What i want to know is , is it just a case of ensuring the freezer is loaded properly or as i’m sure is the case , a fault has developed. Any advice much appreciated as i’m sick of dishing out the hairdryer treatment !!!!
    #321896
    chezza
    Re: Whirlpool American style fridge freezer
    Your fridge freezer should defrost itself automatically . With sense, it should make little difference how you load the thing, as long as loose paper and wrapping arent permitted to clog up the grilles .
    It souns like the automatic defrost has failed for some reason – if you are competent with test meter , it should be fairly easy to test components and identify what is amiss ; Otherwise, a local engineer should be more than able. If you are working on anything requiring removal of screws, panels etc, remove the mains plug first please 😆
    #321897
    tatters
    Thanks for the prompt reply , is the auto defrost located in the freezer behind the panel ??
    #321898
    chezza
    there is a defrost heater and bi metallic switch ( thermostat ) behind there, both need testing
    #321899
    tatters
    Thanks for your help Chezza , i’ll let you know how i get on
    #321900
    tatters
    Spoke to an engineer over the weekend and tells me it will be the PCB which will require replacing , he didn,t consider it to be the auto defrost behind the panel. any ideas??? He didn,t pay a visit i spoke to him over the phone
