whirlpool American style SBS F/F icing evaporator
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum whirlpool American style SBS F/F icing evaporator
  • #70950
    holed1
    Hi All
    Hope someone can assist.
    I have a whirlpool FTSB36AF20/3 side by side.
    Had an issue with the temp in the freezer and warning symbol on front LCD panel, that required some capacitors to be replaced on the main PCB.
    Temp fine issue resolved but now have an icing issue evaporator coil constantly freezing over.
    I’ve checked the heat element and have continuity
    Checked the function of the bi metallic switch and that seems fine
    Condenser kicks in and out like it should
    Am I missing something, any help would be greatly appericated, new baby in the house so under pressure to resolve.
    #379451
    Re: whirlpool American style SBS F/F icing evaporator
    You only have the defrost heating element, the thermostat and the control board so, if two from three are okay… 🙁
    holed1
    Kwatt, thanks for the prompt reply, ran the inbuilt diagnostic but did not indicate a problem looks like have to purchase new fridge.
