I cannot find any model number anywhere on this machine. 😕 I need the pump assembly that fits on the front of the motor. It looks like the old Indesit L5 spin pump back when Indesits lasted more than 15 minutes. It has a white plastic body secured to the motor by 2 spring clips and the pump impeller is black rubber.
I just need a part number. Any help appreciated!!
iadom wrote: had one last week with a failed flexible drive.
The drive coupling on these is the same all through the range, the pumps are similar except one has an inlet and outlet the same size, the other has a small outlet and large inlet.
