whirlpool american tallboy fridge/freezer – fridge too cold!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum whirlpool american tallboy fridge/freezer – fridge too cold!
  • #7829
    Pat
    I have a whirlpool american fridge/freezer (2-3 yrs old) and although it has a temperature gauge inside which swings from 1-4-1 the middle being the ideal, even at its so called warmest setting my fridge is far too cold to the extent sliced meats are becoming frosty – frozen!
    The freezer compartment is fine. I have cleaned it all out but still to no avail.
    Please help!
    Pat
    #125352
    Dave_Conway
    Re: whirlpool american tallboy fridge/freezer – fridge too c
    Could you post the model number from the rating plate inside the fridge please Pat, we can them advise of possible causes 😀
    #125353
    Pat
    Thanks Dave for replying,
    Model No 3XESOFHQKQ00
    Type AR2740-W
    Hope this helps!
    #125354
    Dave_Conway
    Could you double check that number please Pat, I can’t find it listed.
    If there’s a bar code on the label, could I have the two long numbers above and below it.
    Thanks.
    #125355
    Pat
    Sorry Dave,
    the Type No should read ARZ740/W
    The only other number is code 8586-740-01000
    the model number remains the same maybe the ‘O’s should read as noughts!
    #125356
    Dave_Conway
    Ah, electronic controls on this model.
    Expert attendence required in that case Pat.
    Please have a look at repairs@ and the directories to see if there’s an engineer in your area. If not, pop up your postcode and there should be someone here who can help 😀
    #125357
    DentedPorsche
    Hiya, As far as I remember this appliance has thermostats fitted. Could be a faulty fridge stat causing the problem.
    DP
