Whirlpool American Td
  • #21420
    cornwell40
    Given up trying the search on this, it keeps losing the thread after the first couple of pages. 😥
    Model 3LER5436EQO
    Completely dead. Tested the push switch,door switch, thermal fuse etc, all ok.
    Does this machine have an inline fuse like the washer version , if so where is it 😕
    Getting live to timer but no neutral.
    Any ideas ❓
    Tony C
    #190772
    cab
    Re: Whirlpool American Td
    hi tony havent worked on wpol for a couple of years but from memory the stats caused similar problem, the ducts block with fluff and the stat fails killing machine, I THINK!!!!!!
    dont quote me on that.
    cab
    #190773
    cab
    ps cant remember a fuse like washer in control panel.
    #190774
    gegsy
    Some have inline fuse in loom behind fascia, replacing the 6.5A for a 10A usually sorts 😀
    jwd_73
    Cant find a pic of this model but if this is the newer style (round see through door)
    then there is a slow blow 10 amp fuse hidden.
    as you face the front of the dryer top off on the left there is a black panel along the side held on by 3 screws under this you will find the wires and amongst these (usually under tape) there is an inline fuse.
    on the older models it was in the control panel at the top .
    good luck
    John
    #190776
    Lawrence
    Its the toc on the fan duct
    Lawrence
    Dave will know the par no
    #190777
    cornwell40
    None of em. Bl**dy door switch worked fine when metering with the front panel off, but the pecker had worn a groove between the plastic inner and metal outer door. The switch worked momentarily and then flicked off again. Pecker bent down, problem solved. Thanks for input though, know this machine pretty well now!!!
    Tony C
    #190778
    cab
    dooooh! 😆
