Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool American top loader 3RLSQ8000JQ1
- This topic has 7 replies, 5 voices, and was last updated 14 years, 4 months ago by
Kez.
December 8, 2011 at 1:22 pm #66754
Kez
ParticipantGoing out to this tomorrow American top loader not emptying properly, have never worked on one before, just wondering if any one knows how easy they are to work on or if there is anything engineer should know? Cheers Kez
December 8, 2011 at 5:23 pm #365114clivejameson
ParticipantRe: Whirlpool American top loader 3RLSQ8000JQ1
Given enough access to the front of the machine they are actually quite easy to work on. The pump attaches to the back of the motor so you may be able to pop it off by tipping the machine back. If not then IIRC you just need to undo the back panel, release and tip back the top deck then the rest of the cabinet just lifts away to reveal all.
December 8, 2011 at 7:24 pm #365115clockworkone
as Clive says as long as you have good frontal access these are very easy to strip down.if you want a bit of tech info let me have your email add.paul
December 9, 2011 at 3:30 pm #365116Kez
Thanks ,e mail address sent ,engineer went to it today and the symptons are not as first described he says its filling and emptying ok but there seems to be no drive ,no spin or agitation on wash any advice would gratefully received .In a busy pub and owner has already been back on :rolls: Kez
December 9, 2011 at 4:02 pm #365117Hollytree_Technical
That sounds like the 3 piece motor coupling.
Take the outer case off then un-clip drain pump from motor and un-clip the motor from the gear box to find it.
Prt No: 481932528035
Hope that Helps
Jem
December 9, 2011 at 9:09 pm #365118clockworkone
info sent
December 12, 2011 at 1:01 pm #365119Kez
thanks
kezDecember 13, 2011 at 9:08 pm #365120mikehha
No need to take off outer case just tilt m/c back unclip pump unbolt two motor clips and remove place motor on floor no need to unplug as wires are long enough replace drive coupling then replace motor and pump job done.while you are down there you could spray some wd40 on the brake shoe as this has a tendency to bite !
