Whirlpool American Type Fridge Freezer Model S25DRBB33-A/G
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool American Type Fridge Freezer Model S25DRBB33-A/G
  • #50203
    Taff
    This appliance has a fault code of F1 which is I believe a blocked filter. This was replaced. The appliance was switched off for an hour to reset the fault as per the user manual. The fault is still indicated and the ice machine will not work. The cold water function operates fine with a plentifull supply of water. Any help with this would be appreciated.
    Regards
    Taff
    #303960
    bandit2510
    Re: Whirlpool American Type Fridge Freezer Model S25DRBB33-A
    whirlpool SxS dont have f1 fault, is it alarming after a short period of time or are there other problems. Have you tried the test program.?
    #303961
    Taff
    Thanks for the reply. How is the test program entered? I have very little info on this appliance. Your assistance is much appreciated.
    Regards
    Taff
    #303962
    bandit2510
    Turn off mains for 3 mins, turn back on then open and close freezer door 3x. Test mode will start on its own, display will count down and any fault code will be displayed on front panel.
    #303963
    Taff
    Tried turning off then on and opening the door 3 times but no test function carried out. Still got the F1 Code. Is there a way of cancelling the alarm code. Scratching my head on this one?
    Regards
    Taff
    #303964
    bandit2510
    I have looked at the diagram for this model and it was built b4 the test sequence was introduced. You cannot remove fault manually. F1 is displayed where? check water dispenser/valve, defrost heater, build up of crap behind lower grill (where water filter fits) if all ok it will be main pcb at the rear.
    #303965
    Taff
    F1 is displayed on the display panel of the freezer door.
    Regards
    Taff
    #303966
    lerch
    F1 is change filter.
    {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Litres Time Degree of wear of filter
    F1 1 > 1500 > 270 High (Change the water filter)
    #303967
    Taff
    Already changed the water filter. Everything works apart from making ice?
    #303968
    Taff
    Went to this again today. The fault code if it is a fault code is F1{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}. The ice maker is still not working so I took it off and put a live feed to it and the motor turned the ice ejector assy. Any ideas would be helpful.
    Regards
    Taff 😥
    #303969
    DentedPorsche
    Hiya,
    Press and hold the OK button till the filter percentage resets.
    HTH
    Brian 🙂
    #303970
    Taff
    Thanks for the info machine has now reset to 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}. However it is still not making ice. The tray is freezing the water but the ice is not being shifted to the ice compartment. The motor turns when a supply is conected to the motor assy. Any clues would be appreciated.
    Taff
