customer says drum not turning.
looked at it and the white plastic coupling from the motor to the gearbox looks like it has brocken.
Is this a straight forward job?
Do you just remove the motor and fit a new coupler, or is it a pig of a job.
I’ve never worked on the american style whirlpool before, do you need any special service tools or is everything done from underneath and easy?
can you provide part number for coupler as well please.
thanks very much.
john
easy job …….undo 2 screws that hold the timer/facia panel on [screws at back] then spring out the 2 metal clips and this will alow you to remove the shell [pull the connecter plugs apart] then you can get at the motor 2 clips with screws [1 top 1bottom]then motor comes out change coupling then fit back in reverse waldebeck services on 0208 569 0606 for spares regards dal
