whirlpool amw6100-6k washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool amw6100-6k washing machine
  • #61795
    AASWALES
    hi i have been out to this machine today and the fault is when it is turned on to any prog it pumps then fills for 3 seconds then the door lock light flashes ? the door is locked and the carbons are ok any ideas ??? thanks alan
    #347646
    Re: whirlpool amw6100-6k washing machine
    A poor connection in motor plug could have same effect as worn carbons. BTW should that be awm6100?
    Mike.
    #347647
    AASWALES
    hi thanks for your reply , i have checked the connection it ok , it does seem like a motor fault dont you think ??
    cheers alan
    #347648
    Certainly, the carbons being down do cause some Whirlpool machines to stop dead at varying points in the programme with a door lock fault indication.
    Sometimes a break in a motor wire can occur but be still holding by the insulation. This is often caused when the motor connector falls off its bracket and is able to waggle about during spin. (I hope you’re not my grandmother.)….
    (Especially as she’s been gone a very long time, God bless ‘er.)
    Mike.
    PS. I had a look at your website and like its simple lines. Is it just not running right though, or is it a work in progress?
