WHIRLPOOL AMW8000 DREAMY
Viewing 1 post (of 1 total)
  • #8800
    mbdas
    HI all,
    Had a call today for one of these, customer didn’t know what the fault was just asked if I could call and have a look for her 😮 .The fault is with 28mins remaining the machine flashed up FH1 fill fault and before I got their customers son fitted a new standard fill hose so when I checked the operation of the machine it worked ok then told customer seems ok 😕 then she showed me the old fill hose it was one of those waterblock ones so that was the problem.What I would like to know is how does the waterblock device thingy work as the instruction booklet says do not cut pipe as there is a electricial device in it and no means of connection to source.Also would like to know about common fault codes and how to select a test cycle for future referance as it could be a good earner its in a damp COW SHED
    thanks Mark
