WHIRLPOOL APPARENT FILTER BLOCKAGE
Home Forums Public Support Forums Help And Support Dishwasher Help Forum WHIRLPOOL APPARENT FILTER BLOCKAGE
  • #87755
    Pabster
    We have just acquired (with house move) a Whirlpool dishwasher.
    I THINK that the model number is ADG5720FD – I say ‘think’, because the model is built in and the documentation doesn’t (really – I’ve checked) give a model number at all; as we live in France, it might be a French-specific model number.
    The FAULT is that it fails to draw in water and so each cycle stops very quickly and the error light flashes 8 times which, according to the booklet, indicates blocked filters.
    We have:
    – taken out and cleaned thoroughly (and they did need it) all the filters within the machine, but to no avail;
    – checked the water drainage hose and the drainaway (sorry if these are not the right terms) and neither is blocked: if we put a bowl of water into the machine, it voids that perfectly and the water drains away;
    – checked the water supply which, from the inlet tap to the machine, is fine.
    Neither of us is very technically savvy, but we wondered whether there might be anything else we could try, before calling in a professional (we live absolutely in the middle of nowhere and the firm likely to come out have unfortunately been both very expensive and not very efficient in the past)?
    I do appreciate anyone who takes the time to read this and, even more, any advice; if there is any other information which I could give to help, please let me know.
    Thank you
    Pabster
    79120 La Fontaine
    France
    #435893
    Re: WHIRLPOOL APPARENT FILTER BLOCKAGE
    with all whirlpool dishwasher faults first think to check is broken wires at the bottom of the door
    remove door outer and check
    Pabster
    Thanks for such a quick reply, Dave.
    Mmmmm: you’ve probably no idea how rubbish I am at anything practical, but I’ll see if (even) I can get inside and check and I’ll report back.
    Thank you again.
    #435895
    Pabster
    No evidence, as far as I can see, of broken or detached wires, so more suggestions welcome……
