Hi all my whirlpool aqua stream 9759 has started to leak water from underneath the machine. Not sure if its a seal or drum leaking. Any help appreciated. Thanks in advance Gary
The problem was a rubber grommet for the ntc sensor. All fiex . 2 washes later the washer stopped mid cycle with the display flashing. Switched off the machine. Still the same. Had to drain the water from the drum. Now it powers on now and again.Any ideas why the display is flashing ???
