whirlpool aquasteam w/m awod/as128 f06
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool aquasteam w/m awod/as128 f06
  • #57051
    Davecas
    customer rang to say she has this whirlpool washer.
    Model AWO/D AS128 & it comes up with fault F06.
    Anyone know what this is can`t find this model in the fault code list.
    thanks
    David
    #329644
    johnmac11
    Re: whirlpool aquasteam w/m awod/as128 f06
    F06 means the tacho has not detected the motor turning, probably carbons..
    John
    #329645
    Davecas
    thanks for the reply, John.
    I put it on a wash & after 12 mins the motor speed ramped then F06.
    Checked the tacho coil it was open circuit…reset the machine put it on a spin did this ok checked the coil was showing correct resistance.
    Found a scrap motor of same make transferred tacho coil…so far seems to have cured the fault!!!
    Anyone else had intermittant tacho coils?? I`ve seen fill valves do the same thing but so far not a tacho coil.
    Cheers
