Re: Whirlpool ARC5571 Replacing Freezer Door Seal
Hi there
must door seals are very easy to replace unless the seal is part of the door but if you have just a door seal then just pull the door seal away from the door and it should come away from the door but if the door seal looks like its part of the door then you will need to replace the door.
if you get the seal off then just push the new seal on starting from a corner and press the seal on all the way round, the key thing to remember is when you are done, is to make sure that the seal forms to the frame all the way round and check for gaps when the door is closed
if there are gaps then just press the seal in the area where there are gaps and keep checking it in the day and it will start to form.
