whirlpool ARC6700 850167015040
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool ARC6700 850167015040
Viewing 1 post (of 1 total)
  • #73458
    rickard
    This Fridge freezer is showing F02 in the fridge tempature display and you are unable to set anything but both the fridge and freezer are working ok, If you switch the power off and on again it will show the temp and allow you to change settings but after about 5 minutes it flashes F02, I suspect it is the sensor but i can only see the air sensor so if it is an evaporator sensor can this be changed or bypassed, any help would be great.
    Andy
