Whirlpool AWE 6722 error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWE 6722 error
  • #91403
    Mark75
    My Whirlpool AWE 6722 toploader stops after taking in water, after about 15 minutes and then displays an error. It doesn’t have an lcd screen, only flashing leds (spin speed leds) as an error indicator. It has 5 leds, the manual says:
    1st (“0”) “Water inlet fault”
    1st (“0”) + 2nd “Draining fault”
    Other combinations “Electrical components fault”
    1st (“0”) + 4th “Water Stop fault”
    3rd “Foam detection / overdosing of detergent”
    On mine the first (bottom) and 3rd (middle) led starts to flash. This would indicate an “electrical components fault” but this is of course a bit vague….does anyone have more information on the error codes?
    Any help is greatly appreciated!
    #447945
    Re: Whirlpool AWE 6722 error
    i personally have no access to fault codes on this machine but reading between the lines I think it may be your heater. it takes approx that time for the machine to fill and figure out the temp is not going up inside the drum
    will it do a rinse and spin programme as the heater is not needed then ?
    Mark75
    Thanks for the quick reply Dave. That sounds logical, I will check if it rinses/spins later today. Is it likely to be the thermostat or the heating element, or are they usually replaced at the same time?
    #447947
    heater and thermistor (thermostat) are 1 unit
    Mark75
    Apparently they are two separate parts for this machine. The machine finishes the rinse/sin cycles as normal, so I’ve ordered a NTC to start with. I’ll report back with the result.
    #447949
    did you check the heater for continuity first ?
    Mark75
    I just put in the new NTC and that solved the problem! Thanks for your help Dave.
