The fault on this machine is no pump action.
I`ve checked the obvious and even changed the timer.
I`ve removed the pcb,checked for dry joints and loose cables but everything checks out OK but there is no live to the pump so I presume its the board itself.
As the boards are very expensive,am I right presuming this or does somebody know different?.
Chris,
It’s that damn SMEG built machine, board faults quite common. If you can post up the board number, Dave Conway can probably find it as a SMEG part, which is definitely cheaper.
